depending on if the ES in your GS8 was replaced or if it was updated, from 07-09 (& very early 10)
the ES had two defeatable body sensors, with 2 switches on the pre-amp circuit board, while the
newest version of the ES has a discrete pre-amp & one body sensor, with one switch on the pre-amp
the current ES utilizes a magnetic dynamic string (neck) sensor, which is not defeatable, & a dynamic body sensor
i had a guitar with the K&K pick ups (can't remember if it was the pure western or mini) &
i found that it was quite prone to feedback, which could be a concern with high stage levels
i'm going to try to compare the 2 body sensor ES to the current system,
along with the LR Baggs iMix & anthem when i'm at the music store tomorrow
i was able to compare the iMix & anthem already & i like the warmth of iMix, but
the clarity of the anthem was quite impressive also - the guitars are very different
as well & both systems were able to reproduce the guitar's 'native tone' quite well
