if there were a situation to where the cable might be 'yanked' from the guitar (in the playing position),
i'd rather the cable go straight out & away, rather than down or at an angle ... but that's just me
a cable with a right angle end, or a stand to keep the output jack area off the ground would likely help -
leaning a guitar up against something could be a repair waiting to happen (i'd try to avoid doing that)
Hi Michael,
I've quoted excerpts from two recent posts of yours, one from this thread and one quoted from the "should the end-pin jack be moved" thread.
You point out a disadvantage of a straight 1/4" plug and one for the right angle version.
Even though I'm a newbie on this forum, I've already seen from your other posts that your opinion is to be valued, so I'm interested in your (and others') view on this aspect of the cable. At the risk of moving even one level deeper into minutiae, I'm hoping to get more insight from experienced Taylor acoustic cable users before I "chart my course" on cables. On the one hand, it seems silly to put so much effort into such an inexpensive item, certainly relative to the cost of the guitars. But on the other hand, both concerns you mention address risks to the guitar itself, so it's hardly a trivial consideration.
Personally, your "yank" point seems to address the most significant risk and has nearly convinced me that a straight plug is preferable. Although it was many decades ago, I still remember how frequently the cord would get yanked out of my electric guitar during my rock 'n' roll band days. Dozens of times, I'm sure, both during performances and practices. Fortunately, (if my recollection is correct) the jack on my Gretsch was pointed almost straight down when I was wearing the guitar, and the cord usually came out. I think I sometimes used angled plugs, but fortunately my Duo Jet was built like a tank, albeit a semi-hollow-body tank, and I think I might have damaged a cable or two when the plug didn't come out, but it never harmed the guitar. And early on I learned to wrap the cable around the strap at least once, not to guard against the strap coming off--that just never happened; it was on tight--but to prevent yanking out the plug during a performance. (I'm also now remembering that I usually used a long, coiled cord, but as usual, I continue to digress.)
Anyway, I definitely see your point about yanking on an angled plug that's inserted into an expensive acoustic guitar. Concerns me. A lot!
![Undecided :-\](http://www.unofficialtaylorguitarforum.com/Smileys/default/undecided.gif)
A straight plug should be much more likely than an angled one to come right out pretty easily in that situation.
So what's the downside of the straight plug? Seems to me, the only one, provided one always uses guitar stands, which I do, is if the plug extends so far out of the body that it hits the floor when the guitar is on the stand (or obviously if one likes to prop the guitar up on its end without a stand while plugged in, but I think anyone foolish enough to do that deserves their fate). I have several of the OnStage GS7462B folding guitar stands, which I really like for the price (as is the case with all of the OnStage products I've bought, fwiw). I just tried plugging in the straight plug of my TS cable and setting the guitar on a stand, and although it forces the cable to make a fairly sharp, short-radius right turn, it doesn't risk any damage to the guitar, and hopefully not to the cable either, unless it's done regularly. Moreover, a straight plug would probably encourage the removal of the cable from the guitar before placing it on the stand. Given that the 9v battery will continue to be drained while the plug is in, that's actually a very good thing. Unless it's only going to be on the stand for a few minutes, unplugging is the smart thing to do from a battery-saving standpoint.
So, there are my thoughts on straight vs. angled. If this topic has already been addressed elsewhere on this forum, I didn't find it, so I'm hoping that any discussion we have here will benefit a lot more people than just me, especially if it saves someone from causing damage to their guitar!
Comments invited! Thanks.
