Author Topic: humidity  (Read 3192 times)
deluxe strat 2012
humidity
« on: January 22, 2013, 08:19:46 AM »
Im going on vacation and its heating season where I live, I do run a humidifier when im home, I will not be able to run it on vacation. would it be best to put my Taylor in its soft case or leavr it out ? thanks
2012 american deluxe strat
2012 Epiphone les paul
2011 Yamaha Pacfica
1974 Alverez 12 string
2012 Taylor 114ce
Re: humidity
« Reply #1 on: January 22, 2013, 08:22:32 AM »
Your best bet would be in the case with a humidifier. I recommend Oasis as a good in-the-case humidifier. Damp-its aren't bad either...
lmacmil
Re: humidity
« Reply #2 on: January 22, 2013, 08:33:14 AM »
I am in the exact same boat although I was able to take my Taylor with me.  I had to leave 3 guitars (1 with all solid woods) at home. I put a couple of damp kitchen sponges in baggies with holes in them in each case.  We'll see how well that works.
Taylor GA3
Taylor 150e
Taylor 224ce-K
deluxe strat 2012
Re: humidity
« Reply #3 on: January 22, 2013, 08:35:28 AM »
i dont have a humidifier to put in my case and dont have time or a place near me to buy one
2011 Yamaha Pacfica
2012 Taylor 114ce
Re: humidity
« Reply #4 on: January 22, 2013, 09:53:35 AM »
When not being played, my guitars live in their cases. Like vampires and coffins...
Re: humidity
« Reply #5 on: January 22, 2013, 02:06:21 PM »
The hard guitar case is preferable for resisting humidity changes. Whether using a hard or soft case, while away for an extended trip, I'd wrap the case in plastic - say, a pair of large garbage bags, taped for a hermetic seal.
sealcove
Re: humidity
« Reply #6 on: January 24, 2013, 06:48:01 AM »
If you have not headed out the door yet, you can make a case humidifier pretty quickly.  If nothing else, an old plastic soap box or other small plastic container can be drilled out a bunch of times and used for this purpose.  Just add a damp, but well wrung out sponge and leave it under the head stock (obviously you want the exterior of the plastic container to be completely dry) .  If you are careful and can leave the guitar case flat, a small one can fit by the heat stock and another at the heel.  Up at the head stock even a partially open sandwich bag with the same sponge in it will work pretty well in a pinch.
Edit: I just realized that you said soft case.  The solution I describe will depend on if you have any open space to work with in the case like a typical hard case would.  If something will fit, but is loose in the case, it isn't a bad idea to leave a sticky note on the case reminding you so you don't pick it up with that stuff rattling around in there.
« Last Edit: January 24, 2013, 06:51:02 AM by sealcove »
Louis
  • Alberta Canada
Re: humidity
« Reply #7 on: January 24, 2013, 07:47:34 PM »
That's what I did yesterday, went  to the dollar store and bought  3 soap containers for a buck each, drilled holes and cut sponges to   fit. I put 2 in the headstock section in my GS mini soft case. I had  wet rages in a bag but they left a smell, so I went this route.
Taylor 315ce Jumbo 2010
Bose L1’s (2)
Fender F65--1977
Taylor 12 string 356ce
Fender Strat - 50's special edition (red)
Heil. Fin  microphone
Fender 512 sub woofer
Digiteck 3 vocal harmonizer
Re: humidity
« Reply #8 on: January 24, 2013, 08:02:14 PM »
The sponges will get stinky too! If you use distilled water they don't get stinky quite as quick. Whatever you do don't leave a stinky sponge or rag in there or your guitar will smell like Grandma's basement.
sealcove
Re: humidity
« Reply #9 on: January 27, 2013, 12:17:42 PM »
I think the stinky sponge issue might depend on your water and how wet your sponges stay between top offs.  I have never had the issue with my well water, but I use smaller sponges and let them almost dry out before re-wetting.
Re: humidity
« Reply #10 on: January 27, 2013, 04:43:50 PM »
If your sponge does start to smell...you can always wash it using dish soap...then make sure thoroughly get all the soap.  Next put it on a plate and throw it in the microwave for a minute or two tops.  It's a great way to sterilize your dedicated guitar sponge.  ;D
Re: humidity
« Reply #11 on: January 28, 2013, 12:37:13 AM »
 Planet Waves Humidpacks are another option.
2014 Taylor 524ce
2013 Martin 000-28EC Sunburst
2011 Taylor 314ce
2008 Taylor SB-1 Classic
