Author Topic: Bridge pins for GS mini  (Read 14749 times)
leeasam
« on: January 28, 2013, 09:29:12 PM »
I am looking to replace the bridge pins on my GS mini with Ebony. will the standard taylor ones work or is there another brand that will fit better. I have heard that they are not the same size as the full sized Taylors. Not sure how much truth there is to it or not.
2010 816CE Taylor
2012 PRS P22 Black Gold wrap around
2012 Taylor GS mini
Re: Bridge pins for GS mini
« Reply #1 on: January 28, 2013, 10:16:08 PM »
I have replaced the pins on my mini with standard Taylor pins which work just fine. I think they are all the same size.
leeasam
« Reply #2 on: January 28, 2013, 10:42:37 PM »
sweet! thanks!
2010 816CE Taylor
2012 Taylor GS mini
Maynard9089
« Reply #3 on: January 30, 2013, 02:04:36 PM »
The ebony pins in my experience were a tad larger. I lightly sanded them to fit. Very easy job and well worth it.
2012 Taylor 414ce
2013 Taylor GS-Mini Mahogany
WirralPhil
« Reply #4 on: February 21, 2013, 06:32:49 PM »
I changed mine for ebony ones off Ebay. They look nice but didn't make any difference to the sound. Slightly tighter fit too.
sonicbaker
    • Sonicbaker Guitars, Ukes, Basses
« Reply #5 on: May 11, 2013, 01:57:15 PM »
Picked up Taylor brand ebony/abalone bridge pins from Sweetwater. They all went in just fine except the 1st string as others have said. Lightly sanded it down and it fit ok. Definitely like the look of them. Not sure I notice any sound differences. Closeup is my avatar, but here's another shot.
http://www.flickr.com/photos/sonicbaker/8729385858/
✫2004 Taylor 354ce L-7✫2010Martin HD-28 ✫2011 Martin D-18 ✫2012 Martin 00-15M ✫2011 Taylor GS Mini✫
fretted
« Reply #6 on: May 11, 2013, 09:19:06 PM »
I bought the standard ebony bridge pins from Taylor, and even though Bob has said they are slightly different sizes, mine fit perfectly. I can't imagine them fitting any better.
1993(?) 410 Special Edition (Rosewood/cut-away)
1995 412
1997 810
1998 Mahogany Baby
2000 714
2010 DN3
2013 Mini Mahogany
2014 522 12 fret
About two dozen other brands of guitars, mandolins, ukuleles, banjos and Venezuelan Cuatros, not to mention the flutes, pennywhistles and the piano.
antsap
« Reply #7 on: February 09, 2017, 06:57:14 PM »
I picked up a Koa GS Mini a few weeks ago. I ordered a set of the taylor ebony bridge pins with inlays and wanted to share my experience.
They fit perfectly on all strings except the low E.
For the low-E, the route in the pin doesn't go up high enough (because of the fat diameter of the low E string).
I fixed this by taking a small chisel and just extending the route (the canal in the bottom of the bridge pin that you align with the string) up a bit more to the top of the bridge pin.
I did this a little at a time until the pin fit nice a snug and bottomed out.
They look great and really class up the mini.
Cheers!
2016 Taylor 814CE
2016 Taylor GS-Mini Koa
2012 Taylor Big Baby
2016 Martin D12X1AE
magirus
« Reply #8 on: March 24, 2017, 01:54:33 PM »
Cheers!
I also bought a GS Mini Koa recently, it arrived on Jan 3rd. Like you I bought a set of Taylor ebony pins with the abalone dots to replace the supplied plastic pins. Although the ebony pins were a little longer and thicker than the plastic all 6 went straight in. I agree that they do look very nice, especially when they catch the light.
