Author Topic: New Taylor - heel & body gap  (Read 2671 times)
clandons
« on: June 04, 2013, 04:41:24 PM »
So, I bought a used 2011 Taylor 214ce for a super price. Everything looks great on it, not a single scratch or scuff, straight as an arrow, in really fine shape. My only concern is that there is a gap between the heel and body. From what I've read, it's pretty common, but I want to be sure. I've posted photos.
Best,
-casey
greg947
Re: New Taylor - heel & body gap
« Reply #1 on: June 05, 2013, 10:05:02 AM »
I have heard that Taylor uses a special putty to fill the gap when it is present.  I own a 2007 GA7 that I bought in 2009.  When I had it checked out by a Taylor tech, the neck needed to be removed and the shims changed. When he replaced the neck, I had a similar gap.  When I mentioned it, he said it was common, and found the putty to fix it.
Greg
2007 Taylor GA7
2010 Taylor GSmini
2010 Taylor GS8e
2014 Taylor 712e FLTD
1973 Guild F212
ctkarslake
« Reply #2 on: June 05, 2013, 10:43:44 AM »
I've noticed such a gap on my 2007 NT neck GC3 but nothing of the sort on any of my PRE-NT necked Taylors.  Don't know why and I cannot imagine the 2007 had a neck reset prior to me purchasing it.
 Maybe someone here can shed some light on the subject.  Maybe it's a little "wiggle room" built in for neck resets, not necessarily something that shows up only after a neck reset?
1989 712
1992 410
1992 412
1995 410
1995 422
1996 412-M
1996 450
1997 412
1997 420-R
2007 GC3
« Reply #3 on: June 05, 2013, 11:20:25 AM »
Hi Casey,
You heard right: normal gap that allows the tech to shim the neck appropriately for the proper neck/body geometry.  No one ever notices said gap because it is filled (if a gap makes itself present) when the neck is removed/replaced for any reason.  That your guitar plays and sounds great means at least it was done properly; yet the tech should have noticed this and filled it accordingly.  A simple task for any "Authorized" factory tech ...call up Taylor and they'll find you one closest to your zipcode.
