I've an '11 GA that needs a reset on the neck. Took it back to the dealer and their factory trained tech that works there mentioned a charge for doing the work. Unfortunately, their shop is not an authorized service center even though the tech is ok'd by Taylor - he had worked previously and another shop that was approved. Taylor wouldn't send them the shim kit.
Called another factory authorized place and he wanted to do a complete setup and include the neck reset as a part of the work.
So, since, I'm in SoCal, called the Taylor CS department and they said I could drop it off and pick it up in a few and that it would be covered under warrantee - and it would be done properly.
Probably be doing that in a couple of days
