those values are correct for Taylor steel 6 string guitars, but there are a wide array of variables -
the GS mini is roughly a 7/8 size GS 14 fret with 23.5" scale & came from the factory with mediums .013 - .056
the specs apply to these models as well -
the baby, a 3/4 size DN 14 fret with 22 3/4" scale & lights & the big baby, a 15/16 with 25.5" scale & lights .012 - .053
GC/X12s, either 14 or 12 fret, 24 7/8" scale for nearly the past 10 years or 25.5", with lights
GA/X14s, again either 14 or 12 fret, 25.5" scale length for 14 fret or 24 7/8", with lights
DN/X10, JM/X15, GS/X16, & GO/X18 models, 14 fret, 25.5" scale with mediums, with some short 24 7/8" scale X10LTDs in 04
the standard specs for all of these 6 string models is 6/64" E & 4/64" e, but there are variances in the factory setup,
as new guitars i've seen over 10 years ago & more current models with bone nut & saddle have been a hair lower
rather than focusing so much on the specs & trying to reduce the neck relief, may i make a suggestion that you try
a small adjustment by turning the truss rod nut a 1/16th of a turn, retune if needed, let it settle in & then play it -
if there is no buzzing & the action still seems a bit high, repeat the process & when it gets to the point where there
is zero relief in the neck or fret buzz before it reaches zero, add a bit of relief back to the neck, see how the action is &
at point if you feel it needs to be a bit lower, try sanding the bottom of the saddle just a little bit, ideally a replacement
saddle so if for some reason the height is taken down too low, you can shim the replacement saddle to determine the
correct height, & then use that saddle & shim to duplicate the height on the original saddle, but if more than a 1/32" needs
to be taken off, refrain from sanding the original saddle, as chances are either the nut or neck shims need to be addressed
by determining the correct neck relief for your personal perference & verifying that there is not excessive relief in the
neck, which can cause the action to be raised higher than a neck with minimal relief, then other factors can be looked at -
i've personally adjusted the neck relief on a new D42 that was so excessive that by the time the relief was with within reason, the
action had lowered to point to where the guitar was extremely easy to fret with mediums &, dare i say it, easier than some of the
Taylors i'd played & owned at that time, so sometimes it pays to look at the easier, reversible adjustments first & go from there
