Author Topic: removing nut  (Read 724 times)
Tim1958
removing nut
« on: October 16, 2015, 08:30:43 PM »
I'm wanting to remove the nut to take some material off the bottom ( lower action at first fret) . On my 616. Does it sit in a channel and knock it out from the side by tapping it or should I tap it out from the direction of the neck. It looks like from the side. Any advice would be appreciated...thanks.
Taylor 616ce 2015
Taylor 712 1996
Taylor 414c3 1997
Baby M 1998
Seagull duett 2 1997
azslacker
Re: removing nut
« Reply #1 on: October 17, 2015, 11:38:01 AM »
Normally the action at that end is set by filing the string slots deeper. I'd recommend having a complete set-up done by your local dealer. Always well worth the money. Nuts are "usually" easy to knock off by placing a block of wood squarely against the nut, and sitting on the fretboard. One soft tap with a hammer will do it, with no damage.
2016 322e 12 Fret
2011 312ce
2012 GS-Mini hog
1983 Washburn D 12S
Yamaha Classical
Ukulele's out the ying yang.
2014 Larivée PO-3 Koa
