Author Topic: Taylor Serial numbers  (Read 11309 times)
Craig
    • UTGF Members Map.
« on: September 19, 2016, 01:20:36 PM »
I'm writing a little app to decode serial numbers.
Has anyone got any valid examples of 9 or 11 digit serials for testing purposes?
I believe they were used from 1993 until the current 10 digit system was introduced sometime after 2000 but I'm not sure exactly when that was.
If you have could you post here or PM me please?
Thanks
Craig
« Last Edit: September 19, 2016, 01:32:56 PM by Craig »
1978 Music Man Sabre II
1980's Charvel Model 6
2014 816ce First Edition
2014 714ce FLTD Sassafras
2016 GS Mini e Koa
2017 Avalon A2-20c
And an Eastman Mandolin!
Visit the UTGF Members Map
jrporter
Re: Taylor Serial numbers
« Reply #1 on: September 19, 2016, 03:54:20 PM »
This comes straight from the Taylor Guitars website:
Monday, January 9, 2012
By: jonathan.forstot
Q: When was my guitar made?
A: The new, 10-digit serial numbering format identifies the factory of production, year, date and the assigned number of the guitar on that day’s production schedule, although the numerical sequence is slightly different from the previous system. For example, the serial number for the first guitar built in the El Cajon factory on November 2, 2009 is 1011029001. Here’s how it breaks down:
FACTORY   YEAR (3RD DIGIT)   MONTH   DAY   YEAR (4TH DIGIT)   PROD. SCHED. #
1   0 (2009)   11   02   9 (2009)   001
Factory designation: 1 = El Cajon 2 = Tecate
Accordingly, the serial number for the first guitar built in the Tecate factory on November 2, 2009 is 2011029001.
From 1993 until the end of 1999, each Taylor guitar featured a nine-digit serial number that precisely pinpoints when work was begun on that guitar. As of 2000, the serial number expanded to 11 digits to accommodate the four-digit year designation. Reading left to right, the first two digits (or four starting in 2000) represent the year; the second pair of digits represent the month; and the third pair of digits represents the calendar day that work was begun. The seventh digit is a series code number – 0 for 300 or 400 Series, 1 for 500 thru Presentation Series, 2 for 200 Series, 3 for Baby and Big Baby Series, 5 for T5, 7 for Nylon Series, 8 for 100 Series, and 9 for SolidBody Series. The last two digits denote the guitar's position in that day's production sequence. For models older than 1993, please refer to the chart below.
SERIAL NUMBERS   YEAR
[didn't use serial numbers!]   1974
10109 to 10146   1975
20147 to 20315   1976
30316 to [--]450   1977
451 to 900   1978
901 to 1300   1979
1301 to 1400   1980
1401 to 1670   1981
1671 to 1951   1982
1952 to 2445   1983
2446 to 3206   1984
3207 to 3888   1985
3889 to 4778   1986
4779 to 5981   1987
5982 to 7831   1988
7832 to 10070   1989
10071 to 12497   1990
12498 to 15249   1991
15250 to 17947   1992
Craig
    • UTGF Members Map.
« Reply #2 on: September 19, 2016, 05:48:41 PM »
Thanks, that's the info I'm using but I just wanted to test it with real 9 and 11 digit serials before I let it loose.
Craig
2016 GS Mini e Koa
2017 Avalon A2-20c
Craig
    • UTGF Members Map.
« Reply #3 on: September 19, 2016, 07:46:27 PM »
I've actually found some serial numbers that work but does anyone know where they were produced in which years before El Cajon and Tecate?
Thanks
Craig
2016 GS Mini e Koa
2017 Avalon A2-20c
« Reply #4 on: September 20, 2016, 05:23:28 PM »
Thanks
Craig
if i recall correctly, the babies & big babies started in tecate in 06,
the 100 series in 08, 200 series in 09 & the gs minis in 10.
the current serial # configuration did not start until 11.02-09,
but there was a check digit (3rd digit from the right) -
YEARMMDDXYZ
X
0 - satin back & sides with gloss top (el cajon)
1 -  gloss body (el cajon)
other - (i.e. 3, 6, 7) made in tecate
also, the 91 & 92 400 series used a different serial # sequence -
91 - 4-0001 to 1132
92 - 4-1133 to 3152
4-1132
https://www.themusiczoo.com/blogs/news/taylor-guitars-serial-number-dating-guide
« Last Edit: September 26, 2016, 05:19:19 AM by michaelw »
Craig
    • UTGF Members Map.
« Reply #5 on: September 21, 2016, 10:53:05 AM »
Interesting stuff Michael, so where were they made before El Cajon and Tecate?
Craig
2016 GS Mini e Koa
2017 Avalon A2-20c
« Reply #6 on: September 21, 2016, 11:53:20 AM »
As I've read Taylor books/articles over the years, I've made notes on Taylor facts. This is what I have on the subject that might answer your question.
1974-1986: Lemon Grove, CA
1986-1992: Santee, CA
1992-current: El Cajon, CA
2000-current: Tecate, Mexico
March 2016: Tecate, Mexico (new facility/factory)
Interesting fact: My husband and I lived on Santee Rd in MI for 16 years.
« Last Edit: September 21, 2016, 11:58:56 AM by TaylorGirl »
Craig
    • UTGF Members Map.
« Reply #7 on: September 21, 2016, 12:03:04 PM »
Thanks TaylorGirl,
I did try Googling but I couldn't find that info.
Craig
2016 GS Mini e Koa
2017 Avalon A2-20c
« Reply #8 on: September 21, 2016, 12:09:39 PM »
Craig
i'm quite not sure i understand your exact question -
before going to tecate, the babies were made in el cajon
starting in 96 & the big babies in 00,  the 100s (03-07) &
200 series (03-08) were also made in el cajon to begin with
the gs minis began in tecate in 10 (only prototypes were made in el cajon)
in terms of the full size, all solid wood models (300 series up)
they were made in lemon grove in 74-87 -
800 & 900 series, then 700s, 500s & 600s (1st mahogany, then maple)
jumbos (X15), dreadnoughts (X10) & grand concerts (X12)
in 87, Taylor moved to santee & the 400 series began in 91 -
in 92, the factory moved to el cajon, the grand auditorium (X14)
was introduced in 94, the acoustic bass, PS, 300s, koa & walnut series
shortly thereafter, NS, T5, grand symphony (X16), SB, T3, bari
(X16), 12 fret (X12), grand orchestra (X18) models followed
i came across this, but it's hardly helpful
http://www.guitardaterproject.org/taylor.aspx
i put in a # (12345) & got this as a result
Guitar Info
Your guitar was made
in 1976, 1990, 1991 or 1992
Production Number: 12345
12345 can only be a 1990 model, made in santee
4-2345 received no result at all -
92 400 series model that was likely made in santee (or el cajon)
there are other builders that reused serial #s,
but the year model can usually be determined by
the appointments or where the guitar was built
the factory information was on a previous
iteration of the website (2 revisions ago :-\ ) -
note that there is a serial number that positively shows the first guitar
made in santee (5301), as that was a split year & el cajon 16251
(5300 & 16250 were started in one factory & finished in another)
« Last Edit: September 21, 2016, 08:42:54 PM by michaelw »
Craig
    • UTGF Members Map.
« Reply #9 on: September 22, 2016, 03:24:44 AM »
Thanks for all the info, I'll try and include it ib the app including the 400 series oddities.
Craig
2016 GS Mini e Koa
2017 Avalon A2-20c
