Author Topic: Bridge Pin upgrade for GS Mini + questions  (Read 4069 times)
g.man
« on: December 27, 2016, 06:12:28 PM »
I can't figure out why Taylor would use those cheap plastic bridge pins in such a nice instrument.  I ordered a set of Taylor Ebony Bridge Pins with Abalone Dots, and they dropped right in.  Love the look.
Question #1 Anyone know where I can get some KOA tuner knobs?  At least wood.
Question #2 Are there shims under the bridge?  Can the action be lowered a little?
Thanks!
Before and After
Taylor 814ce Dlx
Taylor GS Mini-e KOA
Gibson Les Paul Standard
D'Angelico Premier Series SS
Schecter KM-7 FR-S
Yamaha SLG200S
Yamaha SLG200NW
Carvin CT-6
Carvin HF2
Carvin NS1
Carvin Bolt
Carvin BK4A Bass
Fender Stratocasters x 3
Fender Telecaster
Ovation 1768
Ovation 1858
Ovation UAE148 Ukulele
Yamaha CG180SA
Augustino LoPrinzi Ululele
J Bovier F5-T Mandolin
Steinberger SS-2
timfitz63
Re: Bridge Pin upgrade for GS Mini + questions
« Reply #1 on: December 27, 2016, 09:05:02 PM »
Those Ebony bridge pins look nice, "g.man!"
Can't answer your first question, but I don't think there are shims under the saddle (which is what I think you meant).  The following actions are best taken by your dealer or a luthier, but if you insist on doing it yourself you can theoretically lay a piece of low-grit sandpaper flat on the table and lightly sand down the base of the saddle to lower the action -- but you need to be careful to sand evenly and not to take off too much.
Something you might try before sanding the saddle is to check the relief on the neck, and if necessary, make a truss rod adjustment.  To make the adjustment yourself, you will need a truss rod wrench; or a small screwdriver (to remove the truss rod cover) and a 1/4-inch nut driver (preferably with a 6-inch shaft).  Sight down the fretboard using the edge of it for reference; if the neck has too much relief (bowed such that the middle of the fretboard looks like it has a "dip" in it), the action will be higher than it should be.  The plastic cover on the front of the peg board hides the truss rod nut.  Again, small changes go a long way; as the guitar lays on its back, turn the truss rod clockwise to take out relief.  You can search the interweb for an illustrated Taylor technical guide on the topic of truss rod adjustments.
T5: C1, C5-12, S (Aztec Gold)
g.man
« Reply #2 on: December 27, 2016, 09:25:48 PM »
Yes, saddle...sometimes I type too fast  ;)  My Ovations, Breedlove, etc, all had removable shims to lower the action.  From what I am reading removing the saddle is a little more involved with the electronics on this one.
The neck relief is perfect.  I've adjusted many.  This is not something that is wrong, just personal preference.  I was hopping for shims, as it's harder to come back from sanding :)
« Last Edit: December 27, 2016, 09:40:22 PM by g.man »
Taylor 814ce Dlx
Schecter KM-7 FR-S
Yamaha SLG200S
Yamaha SLG200NW
Carvin CT-6
Carvin HF2
Carvin NS1
Carvin Bolt
Carvin BK4A Bass
Fender Telecaster
Ovation 1768
Ovation 1858
Yamaha CG180SA
Steinberger SS-2
