Author Topic: Where can I get shims to do a neck reset on my GS Mini?  (Read 6520 times)
marc55
« on: January 29, 2017, 08:22:21 AM »
The action on my GS Mini is too high, and I want to do a neck reset; where can I get the shims?
OR: About how much would I expect to pay a music shop to do the reset?
Thank you,
m
« Last Edit: January 29, 2017, 08:57:19 AM by marc55 »
2017 Taylor Roadshow GS Mini AA-KOA, Ltd
2014 Collings Baby- Flamed Maple
1973 Guild D55
Gordo in OZ
Re: Where can I get shims to do a neck reset on my GS Mini?
« Reply #1 on: January 29, 2017, 10:33:35 AM »
I want to know the cost of that too. PM me if anybody lets you know. I was quoted about Aud 110 for a reset and I thought that was high given that its only supposed to be 15 minutes work.
Taylor 714 CE (2015) USA
Larrivee California SE OM19 (2003) USA
Larrivee L-05 Custom (1995) Canada
Larrivee Maple Special Edition Parlor (2003) Canada
Guild D55 (1974) USA
Marshall AS50D
Mandolins, Autoharps, Concertinas, a Mountain Dulcimer and a Harmonium.
« Reply #2 on: January 29, 2017, 11:19:29 AM »
I have personally never heard that Taylor makes these available to end users: it's a tech-item only, be it an indep. shop or a factory-authorized one.  I suppose you can call directly and ask, but I know of at least one instance where a guy was politely told it's NA.
And yes, it's an easy task for a tech who's done it at least once (let alone dozens).  But cost of labor varies, as does skill, and your level of trust, so due diligence in finding a good guy applies as a neck reset/setup is easy to do as much as it is easy to botch.
HAPPYDAN
« Reply #3 on: January 29, 2017, 12:49:29 PM »
I had the same problem with all three of my Tecate Taylors, including my Holden Village Mini. The high action issues were resolved with a truss rod adjustment and sanding a little material off the bottom of the white plastic saddle. I was able to do the work myself, with the help of some very good UTUBE tutorials available online for free. I personally would not go for a neck reset unless it was a very old or abused instrument. But, it's your call, so Good Luck!
Guitarsan
  • Keep calm and play on!
« Reply #4 on: January 29, 2017, 07:44:09 PM »
What Edward said. You can't do it, but Taylor service centers would be happy to.
davidjudd2
« Reply #5 on: January 30, 2017, 03:32:58 PM »
And if you are the original owner, it's under warranty!
