Author Topic: Taylor's New Website Q&A  (Read 59776 times)
greg947
Re: Taylor's New Website Q&A
« Reply #180 on: March 08, 2013, 11:09:30 AM »
Old back issues of Wood and Steel are available at:  http://legacyweb.taylorguitars.com/woodandsteel/
They go back to Spring 2001.
Hope this helps.
Greg
2007 Taylor GA7
2010 Taylor GSmini
2010 Taylor GS8e
2014 Taylor 712e FLTD
1973 Guild F212
jivauk
  • Sadly Jimmy lost his fight with cancer 3 Nov 2015
    • singer/songwriter duo, a gentle blend of acoustic instruments and vocal harmony
« Reply #181 on: March 08, 2013, 12:09:53 PM »
Hope this helps.
Greg
Thanks, Greg - very much appreciated. I'm off there right now to start downloading!  :)
Val
www.jiva.co.uk
Guitars: Taylor, Yamaha, Eko
Ukuleles: Kala
Sound System: Bose, AER
mauisunset
« Reply #182 on: March 09, 2013, 06:08:46 PM »
Hope this helps.
Greg
Super helpful, Greg.  Thanks!
1. 1997 414ce (Sitka/African Mahogany, pinless bridge, satin finish)
2. 2007 Baby (BT1)
3. 2002 Fender CIJ Telecaster w/ Bigsby & Mastery Bridge
4. 2012 Builder's Reserve VII (12 fret Hog)
Nomad
« Reply #183 on: April 03, 2013, 09:07:41 PM »
What's wrong with Taylor's website?
Only "CE" models are shown from the 500 Series down. I tried to find info on the 314, and it's not even shown. I started pokin' around, and couldn't find any other non-CE models, unless it was in the 600 Series and above.
Seems pretty poorly managed. Did Taylor yank these models and not tell anyone?
fretted
« Reply #184 on: April 07, 2013, 10:40:29 AM »
It seems there is a bit of a desire to have older issues of Wood and Steel available to view on the website . . . perhaps the entire library. It's a delicious treat. And while some info gets stale, insight, specs and great writing never do . . .  and it's fun to survey the aging of Taylor's cast of characters along with our own.
1993(?) 410 Special Edition (Rosewood/cut-away)
1995 412
1997 810
1998 Mahogany Baby
2000 714
2010 DN3
2013 Mini Mahogany
2014 522 12 fret
About two dozen other brands of guitars, mandolins, ukuleles, banjos and Venezuelan Cuatros, not to mention the flutes, pennywhistles and the piano.
Nomad
« Reply #185 on: April 07, 2013, 01:10:14 PM »
Not that there wouldn't be value in that, but they need to iron out the problems with getting the website to reflect what's actually current first, and then worry about the old stuff.
fretted
« Reply #186 on: April 07, 2013, 02:57:18 PM »
Thanks to jivauk:
-"Old back issues of Wood and Steel are available at:  http://legacyweb.taylorguitars.com/woodandsteel/
Thanks to greg947 for this info - originally published as reply #183 in the Taylor's New Website Q&A thread.
Have followed the link and downloaded them all."
It seems they are available.
1995 412
1997 810
1998 Mahogany Baby
2000 714
2010 DN3
2013 Mini Mahogany
2014 522 12 fret
mediaman09
« Reply #187 on: June 27, 2013, 06:17:07 AM »
Where are the tech sheets?? What Taylor page can I find them on??
Eg, where would I find Taylor Tech Sheet “Truss Rod Adjustment that is referenced here:
http://www.taylorguitars.com/blog/taylor-support/string-buzz-multiple-strings?
I googled it and eventually found it here:
http://www.taylorguitars.com/global/pdfs/truss_rod_adjustment.pdf
But where are all the others??
__________________
Acoustic Electric:
2013 TAYLOR 818E FIRST EDITION (#83)  (Beauty and the Beast)
2013 EPIPHONE AJ220SCE (Campfire)
2010 TAYLOR 214E (to daugther)
Electric:
2010 EPIPHONE SHERATON II
2010 EPIPHONE 335 DOT
2009 GODIN FREEWAY
Classical:
1970 ARIA AC-15
1970 ARIA A551B
sitedrifter
« Reply #188 on: June 27, 2013, 07:20:54 AM »
Several times in your Support section you say:
For more information, review Taylor Tech Sheet “Truss Rod Adjustment.”
Yet it's not a hyperlink, and the tech sheet cannot be found.
Example:  String Buzz, Multiple Strings  http://www.taylorguitars.com/blog/taylor-support/string-buzz-multiple-strings
excerpt:
  • Truss rod adjustment. Taking all the strings off at once allows the neck to relax. Restringing doesn’t always bring the neck back to exactly where it was. If this is the case, a simple truss rod adjustment will fix it. See our tech sheet on adjusting the truss rod. For more information, review Taylor Tech Sheet “Truss Rod Adjustment.
  • Did you change to a different string gauge or tuning? Either of these can change the amount of tension on the neck, making it backbow and cause buzzing. If this is the case, a simple truss rod adjustment will fix it. For more information, review Taylor Tech Sheet “Truss Rod Adjustment.
Unless I'm imagining it, it appears you're working on this section right now. It looks different than yesterday. So hopefully you'll address this soon.
Thanks.
Thanks for the heads up. We'll look into it.
Still cannot find this tech sheet as links were never added and the search function does not return the tech sheet. Would be great if a higher degree of technical information be made available on Taylor's site. It would benefit alot of us who setup our own guitars and such.
Thanks
Site
Mark
  • 2013 Taylor 416ce-LTD (Sitka/Granadillo)
  • 2012 Gretsch CVT
  • 2012 Yamaha A1M
mediaman09
« Reply #189 on: June 27, 2013, 07:52:46 AM »
....Still cannot find this tech sheet as links were never added and the search function does not return the tech sheet. Would be great if a higher degree of technical information be made available on Taylor's site. It would benefit alot of us who setup our own guitars and such....
For now, its here: http://www.taylorguitars.com/global/pdfs/truss_rod_adjustment.pdf
__________________
Acoustic Electric:
Electric:
2009 GODIN FREEWAY
Classical:
1970 ARIA AC-15
1970 ARIA A551B
sitedrifter
« Reply #190 on: June 27, 2013, 08:26:25 AM »
Thank you for that link!!!
Mark
  • 2012 Gretsch CVT
  • 2012 Yamaha A1M
mediaman09
« Reply #191 on: June 27, 2013, 09:07:27 AM »
You can also use  for now this link (it;s a google search string) and you see about a dozen tech sheets:
https://www.google.ca/#sclient=psy-ab&q=http:%2F%2Fwww.taylorguitars.com%2Fglobal%2Fpdfs&oq=http:%2F%2Fwww.taylorguitars.com%2Fglobal%2Fpdfs&gs_l=serp.3...27302.31227.0.31967.12.12.0.0.0.0.177.1393.1j11.12.0...0.0...1c.1.18.psy-ab.7UTCsOZxQ6g&pbx=1&bav=on.2,or.r_qf.&fp=ba31a0e8fb3e40fd&biw=1413&bih=919
I absolutely do not understand why they refuse to post their own tech sheets on their own web site!!!
__________________
Acoustic Electric:
Electric:
2009 GODIN FREEWAY
Classical:
1970 ARIA AC-15
1970 ARIA A551B
sitedrifter
« Reply #192 on: June 27, 2013, 09:52:10 AM »
Thanks for the link. I just saved all of them to my PC.
Mark
  • 2012 Gretsch CVT
  • 2012 Yamaha A1M
greg947
« Reply #193 on: June 27, 2013, 03:08:05 PM »
You could also go here (Taylor's old website stuff):  http://legacyweb.taylorguitars.com/contact/customerservice/
On the second menus bar you will see "Tech Sheets".  Go there and find the original 20 tech sheets.
Hope this helps.
Greg
2007 Taylor GA7
2010 Taylor GSmini
2010 Taylor GS8e
1973 Guild F212
mediaman09
« Reply #194 on: June 27, 2013, 03:51:23 PM »
Hope this helps.
Greg
I see the button for Tech Sheets, but it no longer works (for me anyway). I am on IE10, Windows 7, desktop.
« Last Edit: June 27, 2013, 04:19:09 PM by mediaman09 »
__________________
Acoustic Electric:
Electric:
2009 GODIN FREEWAY
Classical:
1970 ARIA AC-15
1970 ARIA A551B
